WTB 6.0 LQ4 Flywheel and Clutch
I need a 6.0 Flywheel and Clutch. Please let me know if you have one you would like to sell @ jsburkey21@tntech.edu
Thank you,
Jake
Thank you,
Jake
I highly doubt you will find one here, there are not many people that have that tranny. If you want a stock replacement get a Valeo, I think they make the factory one. Otherwise Ram, McLeod, and Centerforce, make stronger ones, it all depends on how much you want to spend. I put the centerforce in my truck and it works fine, but I'ver heard of people having issues with the weights coming apart and sometimes at high rpm shifts the master doesnt have enough power to disengage the clutch. Just some food for thought
I am hoping someone out there took out their stock clutch to swap in an aftermarket one, or got a 6.0 from the junk yard that was a manual and used the motor in an automatic truck.
What does the transmission type have to do with it?
Thank you,
Thank you,
I was just saying that GM didn't build many trucks with a 5spd, and there are not many people on here that have a standard trans so there aren't that many parts floating around on this site, there are some but they are hard to come by. I wasn't trying to come off harsh, but thats what i've found when I started looking for parts. Also for the most part if someone needs the aftermarket clutch its because the stock one can't handle the power. Heres a pic of my stock clutch after maybe 2k miles with a magnacharger. There was just too much torque and when I got on it it would slip. Also trying posting up in the Classified section for parts you'll have better luck there. There is a Valeo on Ebay, right now for under $300 but doesn't have a flywheel, otherwise a Centerforce is $600 new and has a flywheel.
Hope this helps with your search.
thank you for your help. I will search the classifides and see if anything turns up. That clutch and flywheel looks like its seen better days.. LOL, its pretty bad when you can see the hot spots that bad.
Tigger Welder
10-01-2015 09:41 AM
FormulaZR
09-14-2015 06:23 PM
04, 2500hd, 4x4, 60, centerforce, clutch, flywheel, ford, gm, lq4, nv4500, powerstroke, problems, replacement, sale
