Yank PT3200?
Yank PT3200?
does anybody tow with one of these? I dont expect to tow often but when I do it will be 6-7k for several hundred mile at a time. can this TC still work ok for me?
if you are going to be towing, i'd say check out the TT series. However it limits you to a TT3000.
I recommend Circle D, give chris a call and he will recommend what is best for your needs.
whats the towing capabilites as he will be pulling a heavy load? I glanced at yanks site and didn't see anything mentioned, just saw it mentioned on the TT series.....being heavier duty i'd believe its capable but it doesn't mention it
I run a CircleD 2600-2800 and tow with it, Chris recommended to go with it or if I didn't tow too much a 3000. After having it for awhile I do not think a 3000 would be that bad, as long as you have a big enough trans. cooler.
