Which year GMT800 trucks switch to bigger brakes (front)?
Old 11-27-2009 | 07:35 PM
jhe2003's Avatar
Originally Posted by skolman91
I wanna say they went from 14" to 15-16" but not positive on that. and i dont think you can fit 15" wheels on the drums can you? there still pretty big, also i dont care how much better drums stop, id rather have rear discs any day of the week just for the point of what an eye sore drums are! I mean seriously, its its almost 2010 and gm goes back to drums, are you kiddin me..
They switched from a 12" rotor to 13"
Old 11-27-2009 | 07:42 PM
skolman91's Avatar
well guess i wasnt close at all, maybe i was wishing subconsciously they were that big..
Old 12-04-2010 | 03:29 PM
MISTERIO's Avatar
does any body know if 05 brakes actually brake better or works beater then 04
Old 12-04-2010 | 05:47 PM
TIM Z's Avatar
11 sec. Truck Mod
The 05 up front brakes are a great upgrade to an 04 and down truck ive read.
I bought the larger 05 up dual piston PBR calipers, and Suburban rear dual piston calipers for my 2000, hoping to get better braking performance,
I also bought Russell SS brake lines and am going to get power slot rotors and ATE brake pads.
The only other thing us pre 05 guys can do is add hydroboost but im going to see how the better caliper/rotors work first.
And X2 on hate changing drum brakes, disc are MUCH easier.
Old 12-05-2010 | 03:09 AM
Blown06's Avatar
8 Second Truck Club
edit:I was corrected, went from 12to13" .
My 15" bogarts bolted right up to my drum rears with no modification. The fronts however required some grinding. In addition to going from 12" to 13", they also changed to dual piston calipers on the front. Mines an 06.
Old 12-05-2010 | 04:07 AM
pewterliftedz's Avatar
actually they just went to a larger Dual piston. mines a 00 and it has dual piston
Old 12-05-2010 | 08:44 AM
LS1TRUCKGUY's Avatar
hmmm... mine has single piston front calipers...
Old 12-05-2010 | 11:14 AM
skolman91's Avatar
wow older thread, forgot about it. This past summer i threw on some stock size drilled and slotted rotors with ceramic pads and am pleased with how much better they stop.
Also after taking off my 55k stock stuff i found out the insides of rotors front and back(Back was worse) were so corroded with build up that only half the pad was actually working and touching. So im sure that helped some to get that out of there..
Steve-O-08
04-19-2018 10:32 AM
SLOPONY
20
10-18-2016 07:05 AM
black6spdz
07-16-2015 02:32 AM
supersportsteve
07-04-2015 01:02 PM
