$300 lq4 rebuild & swap
Old 03-16-2012, 05:09 PM
TXSZ66AVLANCHE's Avatar
369.60 cubic inches
Old 03-21-2012, 01:32 AM
gonzo 6.2's Avatar
early 5.3 and 6.0 used the same cable TB,wouldnt worry bout sensors,use them,probably had lifter tick,shave .020 off the heads tick would likey be gone
Old 03-22-2012, 09:23 AM
Nflddog1000's Avatar
I went with flat top pistons, mild head work on the 317s bigger intake valves, Vinci trucker low lift cam can upgrade to 1/8 rockers which Roger recommended for 20-25 more horses ? Complete TBSS intake and 87mm TB other mods in sig, est hp/tq ?
Old 08-11-2012, 03:09 AM
Well guy it's been a while coming together, real busy at work,little problem now motor don't want to separate from tranny any tips afraid of breaking bell housing
Old 08-12-2012, 10:38 AM
Hunt&Fisherator
silver-mod-o's Avatar
Soak down the joint with penetrating oil and let sit overnight, re soaking every couple hours. The next day, tap around the bell housing with hammer to break loose. May need a pry bar against the block to pop it out of there. Keep at it, it'll happen.
Old 08-12-2012, 12:26 PM
Tks man I try that, it's been a b**ch doin this in driveway the under work is killing me
Old 08-12-2012, 02:05 PM
JFOLM's Avatar
Sorry to ask but did you remove all of the bolts?
Old 08-12-2012, 02:12 PM
LOL Can't find anymore
Old 09-19-2012, 10:43 AM
http://i1075.photobucket.com/albums/...ps92a91a07.jpg
Old 09-19-2012, 10:58 AM
The difference in intakes http://i1075.photobucket.com/albums/...ps83125a63.jpg
Quick Reply: $300 lq4 rebuild & swap
