$400 TO SPEND.. WHAT SHOULD I BUY?
Re: $400 TO SPEND.. WHAT SHOULD I BUY?
i am assuming the times in your signature are from an F-body. at first i thought you were posting times from a stock 5.3 EC. probably start out with a programmer. see how much it improves your times or SOTP. advance the timing and definitely bump up those shift points because when you install intake and exhaust, you'll benefit from it, especially at a high rpm. the talk here is go with a predator programmer. it should be in your price range
Tech Fanatic
I agree a predator would be a great idea. Probably one of the best mods i have done on my truck. With headers and the other bolt ons you have your top end power will be sick, especially after raising your shift points and rev limit.
I was planning on doing edit for the F-bod and adding the truck on to that.. So I'm looking for bolt ons.. Headers/catback/intake ect..
Can't get any decent headers for under $400. I would go with UD pully, intake K&N or UPD, and exhaust cut out. Should gain around 30 rwhp. This would cost closer to $500 though.
jscherbs
09-30-2015 07:54 AM
