*Great Exhaust Info..... Horsepower ratings..
Old 08-05-2011 | 11:53 PM
Bigschwerm's Avatar
Default *Great Exhaust Info..... Horsepower ratings..
I recently swapped over to a true dual 2.5" exhaust setup and stumbled across this info over on Tech while searching for hard data on exhaust setups....
I found this on another site and figured I'd post it here for everyone’s education...
“Hey guys I just got done reading a good article in the May 2005 issue of Popular Hot Rodding Magazine. The article was written by David Vizard who seems to be one of the most accredited and respected people in the automotive performance world. In the article he stated that CFM is a great way to help develop a zero loss exhaust system. For zero loss a exhaust must flow 2.2 CFM per horsepower (This means less than 1% of total power produced by the engine is lost due to back pressure.). From reading the article I think that a lot of people that see gains when going from a 2.5” exhaust system to a 3” dual system see them because the muffler on the 2.5” system didn’t flow enough for their application. David stated that per square inch of exhaust tubing there is 115 CFM of flow. So plugging some numbers into the good ole TI-89….. ((3.14 * radius^2)*115[*2 for a dual exhaust system])/2.2 = Max hp supported with zero loss
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
Now these numbers are assuming that everything else is set up perfectly. The muffler must flow as much as the open pipe or more to get zero loss at the listed hp levels. He also states that using a muffler with a larger inlet/outlet diameter than your exhaust pipe is a great way to get more out of a smaller diameter system since the muffler flow will be able to match the straight pipe flow. Now there are many other things to consider when designing an exhaust system but I figured this would give a great foundation to build on.”
Old 08-06-2011 | 01:41 AM
loloone's Avatar
LS1Tech Editor
Awesome info! I am looking into upgrading my exhaust and was wondering what size I should go for. I think a single 4" will give me the most bang for my buck, but I don't want it to be too loud...
Old 08-06-2011 | 03:33 PM
Duramaxin14's Avatar
is all this with headers or manifolds also what is the best muffler to use?
Old 08-12-2011 | 02:30 PM
Bigschwerm's Avatar
The number are with headers....
flatblack83
03-28-2021 10:28 AM
CD82
09-29-2015 05:45 PM
FlowmasterMufflers
08-17-2015 04:44 PM
KOOKS Headers
07-27-2015 01:43 PM
Quick Reply: *Great Exhaust Info..... Horsepower ratings..
