*Summit Racing's Budget 6.0L LS Build*
LS1Tech Sponsor
We’re big fans of budget builds and that’s precisely what we have on tap for this video series. This is part 1 of 4 for the series. Starting with a junkyard SBE 6.0L LS block with its 317 heads, we're adding one of our Pro LS Vortec truck cams with LS7 lifters. The whole build is being topped off with a Holley Hi-Ram intake manifold. Ford purists might want to skip this next part The engine is going into a 1978 F-100. How cool is that?
Get some handy budget engine-building tips in this episode and learn more about some of the parts used in the build here:
- Pro LS Vortec Truck Swap Camshaft - SUM-8728R1 "Big Torkinator"
- LS7 Lifters with Lifter Guides - SUM-HTLSKIT2
- .600" Lift Beehive Springs - SUM-174004
- True Roller Timing Set - SUM-G6640
- Holley Hi-Ram Intake Manifold - HLY-300-122
Look for part 2 of the series in the coming weeks!
LS1Tech Sponsor
*Summit Racing's Budget 6.0L LS Build - Part 2*
After the teardown in Part One, we’re getting a good look at the condition of this former junkyard 6.0L LS block. Before parts start going back in we need to inspect the bearings and make some key measurements. We lay out more parts for the project and show handy engine assembly tips along the way. It all goes down here in episode two of our Budget 6.0L LS engine build series.
Parts discussed or seen in part two:
- Holley Sniper Throttle Body - SNE-860004-1
- Holley Terminator X Max Engine Management System - HLY-550-917
- Summit Racing Pro LS Aluminum Oil Pan - SUM-121200B
- Melling Oil Pump - MEL-M295
- ICT Billet LS Lifter Valley Cover - ICB-551629G
- Trick Flow Timing Chain Dampener - TFS-K30675600
- Summit Racing LS Oil Galley Barbell - SUM-120116
- We made an error in the video description. We provided LQ9 specs when in fact we have an LQ4 evidenced by its factory-dished pistons. Chevy LQ4 Engine Specs - LQ4
Stay tuned for Part Three to be posted in the coming weeks!
LS1Tech Sponsor
Summit Racing's Budget 6.0L LS Build - Part 3
Episode three of our 6.0L LS buildup begins with the installation of new cam bearings. Along the way, we show you a nifty tool that makes that job easier too. With the cam in and happy we bolt on the rear cover and main seal. Then we move up front to install an upgraded timing set. Then we give you a closer look at the specially-clearanced oil pan we’re using. If you recall, this LS is going into a vintage Ford truck, which means it needs to clear the truck’s front crossmember. Give this video a look and you’ll get a good idea of how this build will turn out.
Learn more about some of the parts used in this episode:
- Dura-Bond Bearings: DUR-CH-25
- Summit Racing Cam Bearing Installation Tool: SUM-900131
- Sunex Tools 3-Piece Flexible Pick-Up Tool Set: SXT-9813
- Summit Racing LS Oil Galley Barbell Plug Kit: SUM-120116
- Summit Racing LS Rear Main Seal Housing: SUM-G2621
- Summit Racing Oil Primer Socket: SUM-900330
- Summit Racing Timing Set for GM LS: SUM-G6640
- Summit Racing Pro LS Aluminum Oil Pan: SUM-121200B
- Trick Flow Timing Chain Dampener: TFS-K30675600
Stay tuned for Part Four!
LS1Tech Sponsor
Summit Racing's Budget 6.0L LS Build - Part 4
It's been a minute since we've updated this. Here's part 4.
After getting the stock 317 LS cylinder heads cleaned up by our pals over at Total Engine Airflow, they’re ready to go back onto the engine. Once the heads are installed, we finish the valvetrain assembly and bolt the valve covers back on. Up front, the LS motor gets the timing cover reinstalled, along with the balancer/damper and water pump. Finally, we top off the entire build with that glorious Holley intake. With the engine build mostly finished at this point, the LS is ready to go into—Blue Oval purists look away here—a sweet 1978 Ford F100 pickup truck.
Parts and Services used in this episode:
- Total Engine Airflow: totalengineairflow.com
- Chevrolet Performance MLS Head Gaskets:NAL-12610046
- Trick Flow Chromoly Pushrods: TFS-21407400
- ARP Balancer Bolts: ARP-234-2503
- Holley EFI LS Hi-Ram Manifolds: HLY-300-122
We hope to have a video of the engine in the truck and on the dyno in the coming weeks. We all know how plans and projects go so it might take us a bit. Stay tuned!
ss04flores
11-18-2008 08:55 PM
performabuilt
02-12-2008 09:38 AM
