00' Tahoe 200k mile 5.3 maintenance build
so my 2000 NBS tahoe just hit the 200,000 mile mark. Its been a pretty rough 200k miles for her, so i'm going through and replacing a TON of stuff so she'll be ready for another 200k
Right now, it leaks coolant like a **** from somewhere outside the engine. my guess is the water pump.
Oil pressure is on the fritz.
i'm guessing its the oil pump on its last leg. possible something clogged in the screen. she's always been hungry for oil too. and the oil pan has a nice combination of oil and coolant build up all over it.
right now my list of replacement parts are:
Melling stock flow/psi oil pump
fel pro oil pan gasket
ac delco water pump/thermostat (stock temp) and gaskets
reman power steering pump w/filter and royal purple p/s fluid
ac delco belts (main and a/c)
ac delco upper/lower radiator hoses
ac delco belt tensioners (main and a/c)
other parts i'm going to replace:
spark plugs (a/c delco rapidfires @ .45 gap ?? current plugs replaced at 120k and are the 4 prong iridium plugs. have had zero problems but i don't really know as i haven't taken them out and checked ever. but i'm pretty sure they were a waste of money. heard these plugs work just fine)
spark plug wires
valve cover gaskets
you can check my build thread over at gmfullsize to see all the current mods
Matt's Tahoe Build Thread - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
started with the water pump removal first
had to get a little creative with the cheapo harbor freight power steering pulley remover. the clamps didn't get tight enough with the metal ring, so i used some blue tape to get it tighter and it worked perfectly.
and its off! (the black piece was part of the p/s pulley remover that got stuck in there)
whole engine
alternator bracket off
is it just me, or do my valve covers look like they're leaking?
and thats where i'm at right now. going to do more research before i continue to get further in to replace my oil pan gasket and oil pump. daily drivers FTW
oh and also one of my rear lift support struts was fucked, finally replaced it and she stays up all by herself! lol
only things i'm concerned about are what all the rest is required to do the oil pump install. really not looking forward to that part
power steering pump replacement is done. wasn't near as bad as i thought it was going to be. this write up helped a TON
Replace Your Chevy or GM Power Steering Pump
where i stopped for the night
spark plug wires
valve cover gaskets
whole engine
lol yeah think i'm gonna break out the cleaner stuff thursday while i'm waiting on some more parts to come in. but mainly i wanted to see where i might be getting leaks from. won't be able to tell if i clean it all first.
I didn't see a Front Main Seal and a Timing Set on your list. Are you planning to replace those? If not, I would highly recommend it because you're going to remove both of them to do the oil pump.
so the rest of my list includes
valve cover gaskets
timing cover gasket set
spark plugs and wires
3 arm puller for harmonic balancer pulley
in the video i saw, they were replacing the timing chain as well. should i just go ahead and do that also while i'm down there?
i thought so too, but when starting, at first i don't have any oil pressure and i hear my valves a little bit, then a second later my oil pressure goes up to 40 and the valve noise goes away. after driving a couple min is when i get the weird jumpy oil pressure/low oil pressure. as far as i can tell the oil pressure sensor and the stepper motor in my gauge are just fine
