01 Tahoe 243 head/cam/converter swap questions
#22
01 burban
I have a 01 burban bought off show room floor. Been doing tons of upgrades this year with it. 6" lift with 3" body. Built trans 4:10 gears built transfer case. I have long tubes with 3" exhaust dumped at axle. Running 102 intake and throttle body. Performance coils intake.has tuner.and a very big sound system in the rear. Truck is bedlinered and on 33x12.5x20s. Im fixing to do stage 2 cam and was wondering what would be the best converter for this build.
tjmath (10-30-2021)
The following 3 users liked this post by Bgbldodge:
tjmath (10-30-2021)
#26
Yes no **** I have 33s right now my burb had a 3" lift till a month ago and 3 months before I put new 33x12.5x20s so tires have very little wear. I just installed the 9" once my 33s are wore I'm swapping to 37s wtf does my tire size make a damn to anyone. I'm asking what would be a good torque converter set up. And no wasn't just a rebuild on the t-case it was the updated set up with the new end housing thanks to pump rub on old case.
#28
Calm down. We are just busting your *****.
arthursc2 is right though, do the gears before the converter. You'll gain far more from those than a converter at this stage. Probably need to step up to 4.56 or 4.88. After those if you want a converter, talk to circle d and have them spec one for you. And even if you don't do the gears, talk to circle d and they can spec one for you.
#29
You wouldn't run 3.02s on 40s, would you? Well, you might. But a smart person wouldn't
Because of a silly thing called "leverage" the tire diameter has a HUGE influence on everything upstream of it. Tire diameter dictates the gear ratio you need in the axles. Weight, gear ratio, cam, displacement, power adders, tire diameter and expected low rpm performance dictate converter. The entire drivetrain is a system of components that rely on each other, you can't change 1 without sacrificing or improving the others
So yeah, size matters
tjmath (10-30-2021)
#30
I wouldn’t expect a 4l60 to last to terribly long with 37s especially under geared, so I’d look at a 4l80 before you do a converter. Then with the 4l80 first gear I would certainly want 4.88s with 37s maybe even 5.13s because 5.3 not 6.0.
One of the work trucks I drive is a 06 RCLB 6.0 4L80 with 4.10 gears, it’s less than spunky with 32” tires couldn’t imagine 37s.
I should add that idk dick about converters cause manual trans is best trans
