01 tahoe stalling and dieing
Truck addict
my sister has an 01 tahoe with a 5.3L. only thing aftermarket is a drop in K&N filter. she said it started dieing on her today. sometimes it would restart and other times it wouldn't. it would also act very sluggish. with the pedal to the floor it would barely go.
Sears auto dept checked the alt and batt and both came back good. they think it might be the computer fouling up. a
anyone have any ideas or suggestion.
mileage is about at 100,000 and i don't know if she has ever changed the fuel filter. maybe once and thats it.
sounds like a few things. some of the guys here already mentioned.
it could be possibly one of these:
- put in a new fuel filter first (needs to be done anyway, plus it is cheap)
- put in new plugs and wires (i think they last 100k miles on our trucks, i would replace it with the same AC delco plugs and wires)
- trying spraying some brake cleaner on the MAF sensor and make sure there are no leaks in the intake tube at the TB and MAF
hopefully the pump did not burn out due to a clogged fuel filter
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
forgot to add it might be a bad IAC valve, but that shouldn't be a problem at cruising speed. i don't think the truck would be sluggish due to that.
sounds more like the truck isn't getting enough gas or spark
Truck addict
well, my sister talked to my bro n law (currently offshore) and he stated that he has never changed the fuel filter. so well see what that does
17,16,15,14,13,12,11 Drvr
did it get a ses light?? it might be the injectors as well have them cleaned. sounds like my old truck did at 80k took it in and cleaned the injectors and it ran fine from then on up to 115k then traded it in lol
Truck addict
Originally Posted by sexyvic1
you may have damaged the mass air flow sensor when u installed the air filter. i think there is a good chance that, that maybe the problem
i just think her truck needs some attention. it just gets driven with regular oil changes.
Mine did the exact same thing when one of my spark plug wires wore out. You might check those. If it is just barely touching anything in the engine compartment it will eventually wear thru and this will happen.
I would check everything these guys have mentioned, but it sure sound like the fuel filter to me. May be needing a new fuel pump soon if the filter is that clogged.
