01 zo6 cam for pulling
#21
Good info
But why not order a custom cam with ALL the specs you like and run it straight up?
Although technically speaking you should be degreeing a cam before installing it but you know what I mean.
#23
Originally Posted by BigTex
I would be ordering a 116 +6, then run it straight up. But if you buy an 01 LS6 cam (the topic of this thread), then an adjustable timing chain is the answer.
#25
Hey tex, what about the comp 9 way adjustable timing chaing and sprockets. Its cheaper than the 4*adv4*ret. If that is better could/would you go more advance, say 6 or 8* on the 01 ls6 cam? Also reco's on retainers and pushrods?
#27
The more adjustable the chain, the more options you'd have. I doubt you'd need to go 6* or 8*. I'd try 4* if it were me.
If you advanced the 01 LS6 cam 4*, I'd say shifts would be close to 6000-6100. In stock form, it pulls pretty good to 6200-6300.
#30
