02 ecm in 99 and no battery light?
Old 08-01-2005, 10:36 PM
Default 02 ecm in 99 and no battery light?
Well I swaped ecms tonight and I thought that when you swap from a 99/00 to a 01/02 that you would have to run a wire to get the battery light out. I havent had mine come on yet. Whats up with that? Its not really bothering me because thats good imo. But just wondering if there might be something wrong?
Old 08-01-2005, 10:46 PM
Zick's Avatar
Do you have a upgraded alternator? Cause that is weird.
Old 08-01-2005, 11:01 PM
No its all stock.
Old 08-01-2005, 11:20 PM
Zick's Avatar
Hmmm, you sure its from a 02'? Got a part number on it?
This will be the first time I've heard someone not getting the battery light.
Old 08-02-2005, 12:48 AM
Ws6Luvr's Avatar
Default whats the point
whats the advantages of switching from a 99-00 to a 01-02 ecm? is there any worthwhile advantages?
thanks in advance
nitin
Old 08-02-2005, 01:07 AM
Tribe Shaman
PappyDan's Avatar
no false knock issue, and much better fuel tables.
could be that the alt light was turned off in the tune so you would not need to run the second wire.
Old 08-02-2005, 05:55 AM
14 Second Truck Club
JERRY2500's Avatar
That's weird because I had to add the wire to turn of the blinking light. You will also have to tune the pcm for the smaller 19# injectors or upgade to the larger 24# injectors. I have a set of stock 24# injectors if you need them.
Old 08-02-2005, 06:50 AM
Well now that I think about it. We did use the tech2 to do this. So I may have put my 99 program into the 02. I did get the part # to it and it was an 01/02. Would this be ok or do I need to run the 02 program?
Old 08-02-2005, 07:50 AM
JERRY2500's Avatar
You need to run the 02 program.
Old 08-02-2005, 08:38 AM
OKLAGMCRUISER's Avatar
if one were to "run a wire" to get rid of the battery light...where do you run it and to what do you run it?
Pat
Quick Reply: 02 ecm in 99 and no battery light?
