02 ecm in 99 and no battery light?
14 Second Truck Club
Originally Posted by OKLAGMCRUISER
if one were to "run a wire" to get rid of the battery light...where do you run it and to what do you run it?
Pat
Pat
Originally Posted by JERRY2500
Just get your tuner to turn off the code.
Pat
This is what i did. I purchased an alternator clip from the dealer for an 02 alternator. (Part # 15306329). Then i ran a wire from the pcm Red terminal #52 to the alternator.
Pat
perfect...that is the exact info I was looking for, but what wire did you hook the redwire from pin #52 to on the 15306329? and did you still use the brown wire that was originally on hte older harness?
Pat
Pat
It should be the one in the middle. Not sure on what color it is. I'll check later after the rain stop.
I only wish we'd get SOME soon...
So do you still hook up the same wire that was originally there and then this second wire? I appreciate you checking later.
Pat
mmmmm....rain....
Pat
Pat
muncie21
09-07-2015 09:55 PM
