02 SIMMS KICK CODES
02 SIMMS KICK CODES
gut cats Add 02 simms (new)4 weeks ago to 2000 5.3 silverado,and each day will set codes on both banks, clear code with a-tap will set next day ,remove simms and install on 1999 5.3 ( supplier states simms will work on 98-01 5.3) does not set codes reinstall on first truck ,you gessed it -sets codes
any one know answer ??
Thanks for any/all replys Johnny
Adkoonerstrator
Re: 02 SIMMS KICK CODES
Hmmm...that's strange. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Maybe check the rear O2 wiring harness on the 2000 to see if the wires are burned or nicked. Maybe that is causing the code and not the actual SIMMS.
Good luck <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
John
NO did not splice anything
BUT tell me more about the two differant kind of
simms gm used so that I may inquire as to the 02 simms my supplier shipped
thanks Johnny
thanks Johnny
Here you go:
Information - Heated Oxygen Sensor Identification and Usage #99-06-04-020
2000 Chevrolet and GMC C/K Models (Silverado and Sierra)with 4.8 L or 5.3 L V8 Engine (VINs V, T -- RPOs LM7, LR)
Two different styles of Heated Oxygen Sensors are used in the 2000 model year truck production.
Vehicles built at the Ft. Wayne (VIN Plant code Z) and Pontiac East (VIN Plant code E) assembly plants will use the Delphi Heated Oxygen Sensors.
Vehicles built at the Oshawa assembly plant (RPO OSG, VIN Plant code 1) will use the Denso Heated Oxygen Sensor.
<img src="http://www.z71.net/o2sensor.jpg" alt=" - " />
FIGURE: Heated Oxygen Sensor Identification
(1) 1 - Typical Bank 1 Sensor 1, Bank 2 Sensor 1 Delphi Heated Oxygen Sensor
(2) Typical Bank 1 Sensor 2, Bank 2 Sensor 2 Delphi Heated Oxygen Sensor
(3) Location of single key on black connector (Delphi Sensor)
(4) Typical Denso Heated Oxygen Sensor, all locations
(5) Location of two key's on gray connector (Denso Sensor)
<small>[ October 21, 2002, 03:00 PM: Message edited by: BigTex ]</small>
