'03+(electronic throttle) Torque Management...
Old 06-09-2005, 06:23 PM
single digit dreamer
parish8's Avatar
Originally Posted by Tiburon
There and during shifts.
are people actualy loging TM on the launch? i have never seen anythere, just at the shifts.
Old 06-09-2005, 08:09 PM
Originally Posted by David1500
How come in my 05 power breaking is not possible and wheel spin is definately not possible at a stop.................
it is possible just dont apply all the brake fullyi thought thaT it wouldnt power brake but i pressedt the brake just enough to stop it from moving very little and will go burning up to 50 55 60 with nice marks but not super dark.and in the crew cab from a standstill i can burn for about two seconds or less
Old 06-09-2005, 08:35 PM
Zick's Avatar
Check out this link, it shows some great graphs of launches and shifts where TM just destroys the timing.
TM LINK
Old 06-09-2005, 09:03 PM
Flyer's Avatar
There is no TQM on launch, that's what the abuse modes do. TQM is mainly for shifting.
Old 06-09-2005, 09:04 PM
TURBHOE's Avatar
its also traction control this way it don't have to apply any brake just close the throttle body. i didn't think was doing it in my truck but snake eater and i 0'ed it out any way and it seems to help with throttle response
Old 06-10-2005, 08:25 PM
not sure what it is, but if I floor my 8.1 from a stop it falls on its face, 2/3rd throttle and it leaps, wtf!!!!
Old 06-13-2005, 08:04 PM
BIG@BLACK's Avatar
Originally Posted by VortecSierra
I would like to know how TM and other abuse modes are applied on the electronically controlled throttle trucks. Does the ECM's torque management close the throttle blade, pull timing, or both? I can definitely feel the TM working while i drive. I have read it can also cut injector flow? I may consider using nitrous someday and I think the throttle closing and Inj. Disable would be bad. I dont have any logging device to find this out, but hope to get Hptuners.
Any help is appreciated.
YOU CAN GET TORQUE MANG. DELETED FROM YOUR PC IF YOU KNOW SOME ONE WITH LS1 EDIT OR HP TUNER. TOR PULLS TIMING AND INJ PULSE CHANGES AND THROTTLE CLOSES
Old 06-13-2005, 08:35 PM
David1500's Avatar
So what is the most simple solution to having the tq management removed and the problem I have?(The truck wont go over 1500ish RPMS with the brake applied)
Old 06-13-2005, 08:42 PM
therock's Avatar
Default Yes...
...I seen a OE table where the TB never opened over 45%. I believe it is hard to get to open more than that with out a tune.
Old 06-13-2005, 09:42 PM
TURBHOE's Avatar
look in the traction control tables even if you don't think you have traction control and deleate them i'm telling you mine is alot more responsive since we did that.
kalikid06
20
10-13-2015 07:37 AM
99bluefirebird
09-17-2015 08:05 PM
pewter00
09-14-2015 09:17 PM
bisqikss
09-08-2015 03:35 AM
Quick Reply: '03+(electronic throttle) Torque Management...
