03 and up throttle body on 02 down engine?
Is there any reason why you can't put a 2003 and up dbw truck throttle body on a 2002 - 2000 style engine with dbw?
This is my set up, and I have re-pinned the harness for the single large plug of the 2003 - up tb. I have no throttle pedal and am getting code P1220 and P1221. Engine will start and idle - tb will click and whine when you first energize it...but that is it.
I'm getting ready to go through the diagnostic this morning for those codes. I put the tb on a buddies 2003 truck and it moved correctly with his pedal and no codes.
Thanks!
Thanks!
OKay...been out there testing this and that....
I have 5.0 being fed FROM the green signal 1 wire out of the TAC module. So...I don't know if this is how that module is suppose to feed, or if there is a module failure.
The module is new - but is is a 12574421 number - listed up to 2002.
So...do I hunt down a 2002 throttle body to try it out...or hunt a 2003 module...or do I just have a defective 2002 module????
The throttle body does work - I plugged it on my buddies 2003 and it was fine. My engine is newer than the harness I'm working with - thus the mix up.
GreyChevy
07-07-2015 08:57 PM
Gadgetized
07-07-2015 04:40 PM
