04 4.8 Engine Gains and tips
Hello i have just purchased a ton of comp cam engine components for my silverado. I was wondering if anyone could give me some tips on the install and maybe how much horse power i could be expecting? Thanks heres a list of the stuff i got...
- 04 LS2 Heads
- Comp Cams Rockers (13755-KIT)
- Comp Cams Springs (26918-16)
- Comp Cams Hydrolic Roller Lifters (850-16)
- Comp Cams Pushrods (7955-16)
- Comp Cams Timing Chain (7153)
- Comp Cams Camshaft (54-452-11)
Camshaft Specs
Valve Lift: Intake-0.520 Exhaust-0.524
Duration At 0.006 Tappet Lift: Intake-266 Exhaust-270
Valve Timing At 0.05
Intake: Open -5 Close 37
Exhaust: Open 47 Close 11
These Specs Are For The Cam Installed At 111 Intake CL
Duration At 0.05: Intake-212 Exhaust-216
Lobe Lift: Intake-0.308 Exhaust-0.308
Lobe Separation: 115
The build of all this is going to take place this sunday so it would be greatly appreciated if i could get any tips abouts this or opinions it will help. Thanks!
- 04 LS2 Heads
Camshaft Specs
Yea they are the same ive done my reaserch the only difference between ls6 heads and ls2 heads is that the ls6 heads have sodium filled valves. I got that from the GM Performance parts catolog, they also have the same casting number.
