05 e-fans nelson harness need to wire in toggle
Old 07-03-2005, 04:08 PM
Talking 05 e-fans nelson harness need to wire in toggle
Hey I have a 2001 tahoe that I put the 2005 E-fans into. I ordered the nelson harness with the toggle switch and he sent me the standard one. I don't want to go thru the sending stuff back thing. So I wanted to know how do I wire in a toggle switch in it myself? I have to send my tuned Pcm back to Jesse so he can turn on the blue 42 pin. I just should have do that in the first place but I just got a really good deal on the fans. Any help will be great.
Danny
Old 07-03-2005, 05:09 PM
tap into blue 42 pin wire to switch and back to ground
Old 07-03-2005, 05:12 PM
PT's Slowest Truck
budhayes3's Avatar
The PCM grounds pin 42, so I suppose you could just tap into that wire in the Nelson harness and run a wire to a switch in the cab that's wired to ground.
*EDIT*...Whoops, typing slowly...sorry for the double reply...
Old 07-03-2005, 05:48 PM
does it matter what gauge the wire is and does it have to have a inline fuse and what amp switch? I have alot of this stuff in the garage just want to make sure I hook it up right with the correct stuff.
Thanks
Danny
Old 07-03-2005, 06:03 PM
TURBHOE's Avatar
sorry not trying to jack the thread
ok i found a good place to get the fans but where do you get this harness. i went to what i thought was the nelson web site but it didn't show anything about the fan harness.
Old 07-03-2005, 06:50 PM
go to nelson's web site then go to products then click on GM then it's on the bottom of the page under the SC pulley's
Old 07-03-2005, 06:56 PM
TURBHOE's Avatar
ok so its the same for flex-a-lite fans ls1 fans and 05 e-fans? does he have the pig tails for the 05 fans too. and it doesn't say a price
Old 07-03-2005, 08:15 PM
Yes it comes ready to plug into the fans you got to email him and tell him what fans you got and what it's going into. The harness that I got ran me 99.00 shipped. Also if you donot have your PCM tuned to have the #42 pin on the blue side activated the harness will do you no good. Try this (wait4meperformance) web site Jesse can do this to your PCM for 1/4 the price all the other guys are doing it for. PM me for his phone number since I can't post it or the mod will lock this thread.
Old 07-03-2005, 08:23 PM
TURBHOE's Avatar
check sig i've got hpt. thanks for the info
Old 07-04-2005, 06:48 AM
creederado's Avatar
On mY GMC I have A/C with the 05 fans and Nelson harness,
Before the wire went into the PCM I (T- Taped) it and ran into the dash to a 2 way swicth, The other end of the swicth was grounded12v-,
When the swicth is activated(grounded) both fans come on low speed.
I believe I used 14 awg the same size as Nelsons wire, its only a millivolt signal anyways.
I did it a little differant on my Step Side,
I used the A/C lead on Nelson harness to a swicth, Than i took the 12+ and - from the cigrette lighter and ran it to the swicth, The A/C trigger requires a 12v+ mv lead to activate it.
So when that swicth is turned on 1 fan comes on high. Both on high with the pcm activated as well.
hope this helps;
here's the swicth on the GMC;
Quick Reply: 05 e-fans nelson harness need to wire in toggle
