05 e-fans nelson harness need to wire in toggle
Ok I grounded the blue wire from the nelson harness with a switch. It works but they both come on at low speed. I haven't driven it but will it be better to have it come on with the fans on high speed? Just in case?
I got a DPST switch (it has 4 wires and acts like two switches in one) and had a tap off the AC wire on one side of the switch to +12v, and a tap off of the PCM wire to a ground. But you need to put a diode between the tap for the AC and the AC Clutch wire so you don't backfeed the clutch.
This will turn both fans on High anytime weather its cold or hot.
PT's Slowest Truck
SLOPONY
11
09-24-2015 02:47 PM
muncie21
09-07-2015 09:55 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
