05 have elec fans it's true
Old 08-23-2004 | 10:51 PM
Mn Avalanche's Avatar
Default 05 have elec fans it's true
I have a 05 1500 for a rental truck.And im looking under the hood wondering why it looks so huge.Low and behold 2 nice electric fans in there looks super clean.i will take measurements tommorow so i can compare when i get mine back.Factory electric fans be so sweet.
Old 08-23-2004 | 11:53 PM
zippy's Avatar
Old 08-24-2004 | 12:01 AM
lol sorry to bore yu zippy.ya i have read the post prior about them.But till i saw it i had no intrest in em.Esp when i read about the vsc issues ect .Nm i think im going to order a 05 anyways allmost 25k on o3.
Old 08-24-2004 | 02:27 AM
revolution's Avatar
anyone have a part # for the 05 fans?
Old 08-24-2004 | 07:42 AM
Breeze's Avatar
11 Second Truck Club
Im not sure but I dont think thier available yet for over the counter sale
Old 08-24-2004 | 07:50 AM
zippy's Avatar
it's a multiple part number thing. he's correct though, they aren't available yet. i've had a set on order for a bit. some parts are still in quality control testing.
Old 08-24-2004 | 10:55 AM
STOCK_SUCKS's Avatar
They Are Not Available Yet And Its Not Sold As A Set You Have To Buy Every Piece Of It Seperate.
Shroud-89023365
Blade Kit Rh 5blade-89023366
Lh 7blade-89023367
Motors-89023368 Needs 2
Old 08-24-2004 | 03:37 PM
Besides getting the parts together, you will need to do the wiring (power/ground wires, relays?, tap into PCM signal) and have your PCM reprogrammed to turn the fans on and off. Alternatively you could use an aftermarket fan controller and not worry about messing with the PCM.
Old 08-25-2004 | 02:22 PM
revolution's Avatar
Thanks for the info. Im going to wait a little longer and see if the 05 efans pop up on gmpartsdirect before i go with ls1 fans/flex-a-lite fans. I want efans, but I do tow and dont want to overheat. I'm assuming the stock 05 efans will outperform the others.
I can handle the power/ground wiring and I'm going to get a PCM reburn and Nelon's relay instead of an aftermarket controller.
Old 08-25-2004 | 03:38 PM
storm5.3's Avatar
13 Second Truck Club
I just put a set of LS1 fans on mine (99 RCSB GMC Sierra 5.3) about 2 weeks ago and trust me you won't have a problem with it overheating on ya. Never even came close to 210 in the south Texas heat w/ the stock 195 thermo!!! PCM was tuned by Nelson and the fans kick on I'm guessing at about 190 or so. The LS1 fans fit like they were designed to go there and the harness I got from Nelson makes it virtually a plug and play deal. Before I put in the 160 thermo the fans would just run all the time now only one comes on w/ the A/C and the other comes on if I'm in stop and go traffic or just sitting around idling. On the open road it's off w/ just the one cycling on and off w/ the A/C...Zed
Quick Reply: 05 have elec fans it's true
