'05 Ls2 Intake/throttle Body.
Old 07-03-2005, 05:08 PM
RGMEPP's Avatar
Question '05 Ls2 Intake/throttle Body.
Looking at a real sweet deal on ls2 intake and throttle body from a '05 'Vette. Thought was to use as an upgrade on an LQ9 6 litre. Will it bolt up to the 317 heads ?? T.B. looks as though it is actuated differently, can I make this work ?? How about fuel rails etc...??? . Any knowledge greatly appreciated, Bob.
Old 07-03-2005, 05:22 PM
TURBHOE's Avatar
plugs on tb are diff from ours thats about all i know i'm trying to find out myself about the ssr intake with some part #s
Old 07-04-2005, 06:19 AM
tdrumm's Avatar
The TB is controlled differently on the LS2 so an aftermarket TB might be a better option. The intake will bolt up, but the injectors have a different electrical connection, and you'll run into front accessory drive issues just like people who swap on LS6 or FAST intakes. You can either swap to a car accessory drive or Speartech makes an idler pulley relocation bracket and them you'll have to cut down the water pump inlet neck. An SSR intake like stated above would probably eliminate the accessory drive problem. I'd like to see if the SSR intake is worth anything, but I bet it's mucho dinero and I don't have a P/N.
SS94S10
01-03-2019 01:57 PM
natejk
11-15-2016 08:05 AM
gmcyukon
10-05-2015 06:20 AM
trxmxzx
09-29-2015 07:42 AM
maxspeed05V
09-23-2015 10:48 AM
Quick Reply: '05 Ls2 Intake/throttle Body.
