1.85 rockers ?
1.85 rockers ?
What do these do? Where do you see the horsepower?(top end-low end)
My cousin wants to put them on his 01 Sierra 5.3 ecsb. Mods are: K&N Gen II,Descreened maf,Flexalite e-fans,jba cat4wards,transgo shift kit and servo, 4.10 with g-80, and hpp3. His best time is 14.64.
Would he see good gain alone VS combined with a 212/218,918 springs?
They have about 5k miles and are off of joejoe's old setup.
1.85 rocker arms increase valve lift and accelerate your valves more quickly.The increase in power is felt throughout the powerband.The downside of using 1.85 rockers is that they don't generally work well with an aftermarket camshaft and the performance potential of a cam change is greater.You'll also need better valvesprings to take advantage of the rockerarms so there is very little difference in cost verses a cam change.
Formerly one92rs
i am about to install a set. i have the comp 216-220-525-532-114. they are telling me i will end up with near or around 218-221-568-572-114 after i install them. i am also going to install them with the stg 2 heads. ill keep you posted how it all turns out. oh yay my cam spec sheet said that it was 1.85 rocker friendly
KINGCYCLES
10-02-2015 10:21 AM
5.3lSilverado
09-20-2015 06:48 PM
