1 piece EXT cab driveshaft
Old 03-04-2004, 06:10 AM
GREGGO's Avatar
Default 1 piece EXT cab driveshaft
How many of you extended cab guys have a 1 piece driveshaft. I have a friend that had a bad vibration problem in his 4x4 HD. He had it in the shop 4 times with all the standard fixes. Then they finnally replaced his 2 piece with the one piece. You guys think there is any advantage to this? Strength or otherwise?
Old 03-04-2004, 06:32 AM
2ksleeper's Avatar
I have pondered the same question. The two piece drive shaft has to eat-up more horsepower that a single one but I dont know how much. Hopefully someone else will chime in.
Old 03-04-2004, 07:31 AM
1BADHD's Avatar
My HD came with one. I had it out the other day. It only weighs about 20-25 lbs. It was very light.
Old 03-04-2004, 10:40 AM
I thought all short bed ext. cab 4x4s had one piece aluminum drive shafts. With the transfer case its not all that long. My drive shaft is about 6 feet long, but if I could find a good light weight one piece I wouldnt mind swapping.
Old 03-04-2004, 03:50 PM
FAST !!
Great question and idea.
Especially for us lowered guys
Do think Dennys Driveshaft would be able to chime in ?
Give use some advise ?
My shaft look so weak compared to my composite '91
I'm interested
Old 03-04-2004, 03:53 PM
GREGGO's Avatar
I spoke with Dennys early last year about it. At the time, all they offered was a 2 piece. Makes sense about the transfer case. Forgot about that. May be time to contact Denny's again.
Old 03-04-2004, 04:02 PM
zippy's Avatar
i've installed about 30 of those things to elimiate the 2 piece version. they are much lighter and keep the driveline angles more consistant which was a huge problem. they fixed the launch shudder condition on almost every case i installed them in, took some un-needed weight off the truck, and added a bit more power at the wheels. very good mod usually under warrenty. although it doesn't state it in the bulletin, i've also done it on a couple 03's. the bulliten number for those who want to check it out is: 01-04-17-001B.
Old 03-04-2004, 04:08 PM
Greg - you have a vib problem ????
I had one as soon as I put the 2" shackles on
before I went to the 2/4
I have not driven it yet with the 2/4
Waiting on the front springs - frt end is apart
Old 03-04-2004, 04:18 PM
Formerly one92rs
one03sierra's Avatar
Talking
hey zippy where did you get the shaft at and where do we go to check the bulliten????
Old 03-04-2004, 04:41 PM
Alum or composite
Where did you get it
Cost
Were all you did this mod on 2wd ?
Quick Reply: 1 piece EXT cab driveshaft
