1 piece EXT cab driveshaft
Old 03-04-2004, 04:47 PM
zippy's Avatar
the bulletin was for the hd trucks only as far as i recall. they went from a two piece steel to a one piece (very large) aluminum. i do recall a p.i. on the half ton's once, but i'm not sure if i can still find it or not.
Old 03-04-2004, 05:12 PM
JayStew's Avatar
Originally Posted by Fast4.8
How many of you extended cab guys have a 1 piece driveshaft. I have a friend that had a bad vibration problem in his 4x4 HD. He had it in the shop 4 times with all the standard fixes. Then they finnally replaced his 2 piece with the one piece. You guys think there is any advantage to this? Strength or otherwise?
Would this help with the "clunk" that some guys have coming from their drive-shaft?
Old 03-05-2004, 08:48 AM
Greg - were you going to follow up with Dennys or another vendor ?
Skippy - any info you can help us out with ??
Old 03-05-2004, 09:13 AM
zippy's Avatar
i'm going to look into the info if it's still available on the half ton driveshaft. if you were to look into one though, going one piece sure does eliminate alot of problems. denny's could probably make one.
Old 03-05-2004, 11:38 AM
MacADaYear's Avatar
I think thats more the lubing of the driveshaft than length...
When mine clunks I lube it up and im good to go....
Old 03-05-2004, 12:36 PM
I had a custom drive shaft made for my 84 GMC at Austin Driveline and it costed @ $250 for the shaft (steel),new yoke, and new spicer u-joints. To have one made for our trucks shouldnt be much more. I have some vibration when i punch it off the line because of axle wrap. Will a one piece fix this?
Old 03-05-2004, 12:43 PM
marc_w's Avatar
The SS's come with these big aluminum driveshafts.
I'm fighting a bit of high speed shudder. It happens above 80mph, on the throttle. It's not the tires - one of the driveshafts.
I'm working on finding a shop to balance them for me.
Old 03-05-2004, 01:52 PM
The SS has a transfer case - - so the shaft is a little shorter
Us 2wd ECSB guys have a short shaft - carrier bearing - longer shaft
I think Greg and my thought is to replace the entire assy with a 1 pc
long drive shaft
Both his and mine are lowered 2/4 - so the driveline angle cant be that
severe.
On our trucks to do a 2/4 - we have to relo the carrier brg upwards
I was looking at Summits catalog
I was going to measure my drive line angle - see where its at
Old 03-05-2004, 04:45 PM
Try the pathagriam therum for the formula on the angle.
Then agian I quit school,what do I know. Needed more time for my truck
Old 03-05-2004, 08:43 PM
GREGGO's Avatar
I have not contacted Denny's on this yet. I would like to know if GM makes one for the 2wd though. A 2wd 6.0 HD with a 4l65 possibley???? I'll get on it next week. Mine doesn't shutter to bad, and I do have a carrier bearing relocator, but haven't put it on yet. I wanted to research this first.
Quick Reply: 1 piece EXT cab driveshaft
