100k+ 5.3 cam swap, additional parts??
I know there are a million cam threads, but I've been searching for a while now and can't find what I want to know.
I have a 2002 5.3 sierra with 110k miles on it, the engine and trans run strong and have been black bear tuned for about 2 years now.
I'm ready to do a cam swap and headers, and have narrowed it down to a 210-212/218 cam. I've seen that the oil pump should be replaced, along with timing chain, springs, pushrods, etc.
Do I need to change retainers with the springs, or reuse stock?
Do I need to change the timing gears? Are the stock chains roller or not, and will a double roller fit or not fit in the truck engine?
Do I need to change the lifters and trays? How can I tell if I need to change a lifter?
Are the factory rockers sufficient, or will I see any gains from swapping to a roller rocker?
Is there anything else I'm forgetting?
I was planning on dropping the oil pan to get to the pickup tube and o-ring. Since my truck is lifted it won't be bad to drop the pan.
Just looking for people experiences of parts that needed to be changed on a high mileage cam swap...
Subscribed* cause I too am looking to do cam and LT's in my ccsb with 145k on the clock. I think i have bad oil pressure gauge that is pegging at 80 but drops to zero under wot. Hoping its just stepper motor and nothing more. Should I not worry about pump and timing chain yet too? Thanks for any help.
Where's the Beef?
Did my first cam swap at 109k, Second at 170k. The only thing i've changed on my motor is the cam, Springs, valve seals, Pushrods and added headers. Just throw some new plugs in while your at it and keep on keepin on.
Now sitting at 214k miles with no issues.
NGK TR6 is what I run. I wouldn't run E3 in a lawn mower.
I put new autolite irridium plugs in about 10k miles ago along with the 90* boot gto wires that will clear the headers, so I'm good there.
I have good oil pressure, idles just above 40 and goes to 60-70 during wot. So if oil pressure is good I can reuse the stock oil pump?
Since I have to pull the oil pump I should at least replace the o-ring on the pickup tube though?
And I can reuse the stock timing gears, they don't wear out correct? Just get a new single timing chain for peace of mind.
So a cam swap really is as simple as cam, springs, pushrods, timing chain, and gaskets/bolts?
I too did my first swap at exactly 100,700 and we did was new springs retainers and cam.. but no need to pull oil pump unless u need new one. timing chain also. once u take the 3bolts out of the timing gear thats located in front the cam the chain will fall and sit on the crank gear. then just get a magnet to pull it up when u putting it back together,... main thing just make sure the timing is close before the take the gear and chain off.
