100mm MAF for LSX
5 year bitches!
100mm MAF for LSX
100mm MAF for LSX
see im running into an issue with my new duct work being 4" to fit the 90mmtb and that the stock maf is 75mm which is small and a restriction. i was going to go SD but found this. this might just be the ticket
SD is a good tune but can be dangerous, and this will still be in the lines of a MAF tune
I wouldn't call SD dangerous... unless you were running off an untuned VE table with both OL and CL disabled. If this were my setup, I'd save the money on the MAF and spend it somewhere else.
Also, the link didn't work.
Originally Posted by Quik
100mm MAF for LSX
My only concern would be how well or accurate is this device. As well as the longevity of it. I have witnessed a bunch of eratic behavior from aftermarket MAF'S before.
5 year bitches!
yea thats my concern also, this will ponder in my mind for a while. and LPE is a good company so it should be on unlike the SLP one and the grantelli junk.
Originally Posted by TurboBerserker
The big question is when does that one max out? The ad says they used it on the 725hp twin vette, but no hint of max flow.
Can't remember exactly what your plans are Quik, but was thinking a lot of boost?
turbo was out of his budget
Originally Posted by Mater
Quik is going NA. 408 with the L92/L76/ 90 mm tb 1 7/8 headers with svo 42 injectors and a 4" air intake with a healty size cam, hoping to see 7k rpms
I am in no way knocking SD tuning, I am in SD now but evertime the weather changes your ve calculations are off. Plus the mathmatics for figuring the MAF is much more precise with a faster sampling rate (record the waves on a lab scope & play them back). If speed density only was the way to go
then i find it hard to believe GM would not have gone to MAF+SD.
