100mm MAF for LSX
Old 11-26-2006, 05:39 AM
  #21
How do I change this text
Wilde Racing's Avatar
My IAT sensor.
I could not get my a/f were I wanted it between shifts using a maf.....
Old 11-26-2006, 08:56 AM
  #22
5 year bitches!
Quik's Avatar
Originally Posted by CRAZYCUTER4.8
Is he doing his own tuning? If not how will he compensate for the changes that will naturally occur with the ve table everytime the weather changes?
I am in no way knocking SD tuning, I am in SD now but evertime the weather changes your ve calculations are off. Plus the mathmatics for figuring the MAF is much more precise with a faster sampling rate (record the waves on a lab scope & play them back). If speed density only was the way to go
then i find it hard to believe GM would not have gone to MAF+SD.
yes sir, i do my own tuning
Old 11-26-2006, 10:35 AM
  #23
I AM A MOTHERF*CKER
TurboBerserker's Avatar
you are 100% correct in that regard.
They are talking about deleting the MAF all together. In that case there would be no IAT sensor.
You can't run SD, MAF, or any other PCM based tune without an IAT. If you remove your MAF, you have to relocate or replace the GM IAT.
lucas287
31
01-12-2021 06:18 AM
TrendSetter
11-26-2018 07:18 AM
JordanH
10-03-2015 03:59 PM
02AWDAWSDenali
10-01-2015 05:08 PM
racedad70
09-16-2015 01:51 PM
Quick Reply: 100mm MAF for LSX
