110 LSA cams get in here
I run a 224/224 110lsa cam and I know the springs are supposed to be pretty loud but I think there is also another tick coming from the valvetrain. What size pushrods are you guys running? I know there are a few 224/226 110 and 224/228 cams out there. Are you running stock length pushrods? My valvetrain is horrendously loud and I want to make sure that I'm running the correct length pushrods. I might end up buying a pushrod length checker just to be safe
im running a 5.88 lift cam with stock length pushrods and i have a slight tap. my base circle on the cam is like .050 smaller than stock too. i dont have much preload on the lifters is where my tick is comming from and probably yours too. this has nothing to do with the lsa of a cam its all the base circle.
I'm not running the stock length because my heads are milled .025 so I had to get a checker. The valvetrain is going to be somewhat loud but not a "tick". Check your push rod length, loose rocker and for a broken spring or something to that sort.
Hope this helps..........
James
James
noproblems209
08-10-2015 06:57 PM
