111 lsa and driveability?
#21
Tin Foil Hat Wearin' Fool
Originally Posted by RandomHero
I was under the impression that more overlap meant you would make less peak horse power but your powerband would be bigger. Am I mistaken?
#22
Originally Posted by Sport Side
216 -.58X'' and a 222* - .58X''... Do you have part numbers or any more specs on these lobes? Where did you find them?
Edit: comp lobe # 3014/3035 218/224 .605/.600 (1.7 rocker) Id put it on a 110/108 0 overlap @ .050 it would make alot down low and pull up top hard
good drivability
This is the closest I could get with comp stuff or put an xer on the exhaust #3722
#24
crane cams
intake: hr-216/344
exhaust: hr-222/344 put em on a 110/108
.004 277/283
.585/.585 gross lift (1.7 ratio)
-1 overlap @ .050
In my estimation this is the closest I have come to an all around great street/strip cam for what all the guys on here are doing, this is considering an lm7 with 10.5-11:1 SCR stock head ports, truck intake and small diameter long tube headers, open exhaust, 3:73 gears, 2600-3000 stall speed
Sportside: I knew I had seen those lobes somewhere just had to dig for them, I have never tried this cam so Id like to see a cam card on the lobes if anyone has it(wondering about curtain area)
intake: hr-216/344
.004 277/283
-1 overlap @ .050
