12 sec ec 2wd silvy
You could run high 12's for awhile with the stock tranny, but if your getting greedy and want low 12's-high 11's you will need a built tranny. As for cams the 224/224 112 will work good in a 5.3L. Yes long tubes are better, shorties are good, stock manifolds arent that bad. As far as safely running a 200 shot, thats up to you. I've run a 225 dry shot for a year and a half and had no problems exept for the occational spark plug swap every 2000-3000 miles. I have the fuel to support it though and the tuning. Thats the most important thing. As long as you have proper tuning and the right fuel dellivery there's no reason a 5.3L engine shouldnt last a long time with a 300 shot. These engines are extremely strong, and have some of the best stock internaly ever put in a truck.
Originally Posted by Scream
You have lost your mind man. A 300 shot on a stock internal 5.3?
Originally Posted by stretch104
about how often to you guys with 150-200+ shot spray.
Down in FL i paid $2.25 per pound at Automotive Engineering, $3.00 per pound at Speed Craft, $2.50 per pound at Hocus Pocus, and i think it was a little more than $3.00 per pound at Mustang Motorsports.
Up here they sell it at the track for like $5.00 a lb. and in Portland i think I can get it for $4.75 a lb. Either way the track i over 2 hours away and portland is half an hour away. To far and too much to want.
In FL all those places were within a couple miles of my house.
What kind of tuning did you have when you lived in FL? I thought you just got HPT? What kind of fuel system upgrades do you have?
Recommending that someone spray a 300-shot on a stock 5.3 is just crazy.
Fuel system i had then was 32# injectors and vortech inline, and tuning was done roughly at a friends shop in TX with edit. Thats why i was running so rich and only 15* timing at WOT. Hence the plug changes every 2000-3000 miles.
