140,000 mile LS1 engine leak down results
#22
i spin alot of RPM. 7k most of the time. i figure most of my oil is being sucked into the intake. i really was surprised with the leak down results. i figured it had atleast 1 hurting cylinder. i think some new plugs and some breathers in the pcv and oil cap will get me on the road and running 100%. can't wait to get my new exhaust in. and the suspension done.
#30
Resident Retard
if you gonna run breathers, you might want to check with your tuner about how the tune is setup... If you still running a MAF and trims (closed loop), basically a stock step-up tune, those breathers will allow unmetered air to come threw the intake track and cause your trims to max out, basically you would be creating a vacuum leak...
but if you just run breathers and cap off all lines going to the TB, intake, etc. you will be fine...
