1500hd Sucks!!!!!!!!!!!!!
#21
I can get 21-22mpg out of my truck.. but in town drivin it pretty rough keeping the rpms about 2000 i get about 15 or so.. on the interstate ive gotten 21 a few times and 22 every now and again..
Im still not through tuning it though, dont have DFCO or anything like that Enabled.
But i have 275/60/16 tires... 29" Tall and 11" Wide with 3.42 gears, Speedo calibrated with GPS.. 70mph is 2000 rpms exactly.
Ive thought about goin with a 30 or a 31" tire but most of my driving is in town and country roads. so i cruise at about 55mph most of the time..
My buddy at work has a CCSB 1500hd 4x4 6.0 and he gets a best of 14 on the interstate...
#22
I did one a while back w/3.73 gears and 245 tires.I tuned the VE.But when I activated the MAF,it was spark knocking like crazy.
It was doing it before,but not as bad.That why he ask me to have a look at it.
The maf was off by 8%-10%+ everywhere at 35%+ throttle.
After we set the maf and the PE,It ran completely different,a lot better(could not have been worse for sure).He hauls a 28-30ft trailer.He said he got 12mpg with the trailer.I don't remember him saying anything about MPG when he's empty.Don't know if you looked at the MAF allready.If not,have a look.
Good luck
Good luck
#23
I just ran a whole can of seafoam through the pcv. It would idle down to 250 rpms when I let it suck in too much at once and would quickly jump to 3,000rpms and idle there for a minute. I got down to the last 8 ounces or so and just stuck the tube to the bottom of the cup trying to kill it. It took maybe 2 seconds to suck in the entire cup till nothing was left and it didnt even stumble. lol Anyway, i killed it and let it soak 12 miutes. It fired right back up and only had a very slight haze out the tail pipe for maybe one minute. It did idle rough the first couple minutes but cleared up. I tried some full throttle launches and DAMN, for the first time it jumped sideways spinning both tires about 5 feet and went to one tire for another 10 feet. It has never spun the tires before, even with the stock tiny 245's. I am in Brownsville right now so no open streets to get some speed up, but 0-50mph I didnt hear a bit of knock. I may be here a couple more weeks so I wont know if the milage is up any till my drive back to Houston.
I really am impressed with the results but I sure thought the exhaust would smoke more than it did. Maybe it wasnt all that dirty.
#24
Those are some dramatic results from just Sea Foaming the intake! I just did mine 5 days ago with about 1/2 can and it didn't even smoke that I could see. I didn't kill and soak the engine though. I ran a can through the tank a few weeks ago and didn't notice any difference from either procedure. I guess it didn't need it.
I know a guy who has a 03 SSS and it gets 13mpg all the time. I don't know what his gearing is.
My mild-mannered truck gets about 21 hwy on cruise at just under 2k rpm.
#25
I have an '03 1500HD CC with the quadsteer. So the set up should be almost exact. First of all I don't think that the truck only weighs 5600 lbs. I think it's around 6400 or a little more (that's what mine was on the scales). So there is a lot more weight there than you'd think. My truck was crap for milage too when I got it. I got a the 89 octane tune from nelson and that helped a lot. At the speeds you're talking about I'm at 14-15 mpg, and I've never heard better from a truck that big and the 4.10's. I had a '99 2500 regular cab with the same drivetrain and 3.73's and that did average a lot better milage than this CC. The weight and the gears really hurt it.
#27
I had an 04 2500 non HD ( same as 1500 HD) Quadrasteer with the 6.0 and 3.73 gears. I got between 12 and 13.5 on the highway running about 75 - 80 mph. After I got a 91 Hot Tune from Westers my mileage on the highway went up to 14.5. I got popped speeding and did the remainder of the trip not exceeding 70 and pulled almost 16 mpg.
It seems that if you keep the rpms down it really makes a difference. I had an 99 with a 5.3 and running at about 80 mph I could still pull 17+ mpg. The 6.0's are just plain ol' gas pigs.
#30
It's an '06 but only has the 4 speed. Maybe a tranny swap should be the first mod on the list... have to wait and see.
Just found this quote online:
"The Denali is fitted with a 345-hp, 6.0-liter V-8, while the 1500HD is powered by a 300-hp, 6.0-liter V-8."
Wonder if that will make a difference...
