160* Thermo.
Old 12-27-2005, 05:37 PM
Post
No, I didn't feel any difference between the factory stat and the 160* stat.
I don't see it as a mod for adding hp or torque. Just isnt happening.
The only gain from this change is possibly running a few degrees more of timing like mentioned above.
I have heard of guys stating it does lower the tranny temps. This would of course increase life of tranny.
I though on the other hand have noticed a 1 mpg loss. I'm guessing from the coolant staying cooler for a longer period of time, which makes the engine warm up longer, thus burning a bit more extra fuel in the mornings.
That's my assumption. I'm not driving my truck any different.
Jim
Old 12-28-2005, 07:46 PM
TURBHOE's Avatar
Originally Posted by 04BlackGmc
BTw ones for what other cars fit?
I see some people said some fit and some dont?
the 04's have a diffrent housing than the previous models at least 2002 and below and yes as far as i know its the same as the ones for the cars. if you get a part number for the ones for the cars let me know couse i wanna change mine too.
Old 12-29-2005, 10:05 AM
LS1TRUCKGUY's Avatar
Why Is It That Putting A 180 Stat In My Truck, The Temp. Guage Still Reads The Same? Sorry, Im Not Tryin To Steal The Thread, just wondering.
Old 12-29-2005, 03:49 PM
PT's Slowest Truck
budhayes3's Avatar
I had a 180* thermo before the 160*, and I didn't really see a big change either. With a scanner, I noticed that the temp was a few degrees cooler, but not much. For one thing, the factory guage isn't the most accurate instrument. Also, with a 180* stat, it'll open a little sooner than the factory stat (which I believe is 195*), but will still heat up to almost the same temperature if you're using the factory fan clutch.
Old 12-29-2005, 05:33 PM
MHSLOT12's Avatar
Keep The Stock Thermo .. Keeps The Pistons From Getting All Carboned Up !!
Old 12-29-2005, 07:35 PM
PT's Slowest Truck
budhayes3's Avatar
I do an annual induction service to clean the carbon out of my intake, combustion chambers, pistons, etc. Seafoam, GM Top End Cleaner, and BG are different products that I've used with great results. I've used a boro-scope through spark plug holes to view that it works
Dlucke17
07-21-2010 04:27 AM
Vortech S-10
06-13-2007 10:26 AM
stone150
02-12-2007 08:04 PM
03lowriderss
02-04-2006 08:08 AM
Quick Reply: 160* Thermo.
