What's the reason behind changing it? Was to help it run cooler r was the temperature running a little higher then normal?
My 160 runs about 180 depending on weather & if a/c is on! I've seen it go up to 210 on a hot day stuck in traicff
Letting the coolant flow earlier isn't enough to keep the temps low. The fans have a double-duty job of pulling heat off the radiator and pushing heat off engine itself.
