180 stat running 200
Old 07-31-2010, 10:46 PM
05gmcsierra's Avatar
it sounds about rt.. my cuzen got a 180 and he said it stayed rt under 210 and me on the 160 im always at 180
Old 08-01-2010, 01:01 AM
14 Second Truck Club
double047's Avatar
Originally Posted by terravast4
My 160 runs about 175-180. In bumper to bumper traffic never goes above 185 even in 100+ weather.....but the fans are tuned for the thermostat.
This is key, when you run the lower tstat tune the fans to the stat.
Old 08-01-2010, 08:45 AM
Jedi Master
Gh0st's Avatar
Originally Posted by mhotrodscooter
What's the reason behind changing it? Was to help it run cooler r was the temperature running a little higher then normal?
My 160 runs about 180 depending on weather & if a/c is on! I've seen it go up to 210 on a hot day stuck in traicff
Letting the coolant flow earlier isn't enough to keep the temps low. The fans have a double-duty job of pulling heat off the radiator and pushing heat off engine itself.
Old 08-02-2010, 11:38 AM
nonnieselman's Avatar
Originally Posted by 06Sierra2
if the trans lines run through the radiator before the cooler, then will a 160* stat vs the stock one in fact keep your trans fluid slightly cooler?
In theory it should.. cant say ive payed that much attn to that tho.
Oobray
06-13-2022 03:38 AM
X_Racing1
21
03-30-2016 02:37 PM
stealthperf
34
02-14-2016 11:35 AM
ZONES89RS
21
09-24-2015 05:58 PM
BigEd_72455
08-08-2015 07:37 PM
Quick Reply: 180 stat running 200
