1st time on dyno, driveshaft grenaded, carnage insued (long)
Old 05-07-2006, 01:00 AM
blownerator
BlownChevy's Avatar
Had one let loose on us the other day.....damn near shat my pants.
You guys need to remember these things are not breaking from "power" they are breaking from speed. GM did not make a faulty part, it made a drive shaft that works great for a truck that goes max 105 speed limited. These are trucks not vettes.
Old 05-07-2006, 01:03 AM
TouchOfEvil04's Avatar
Could i run an aluminum drive shaft in my heavy *** truck???or would that be too much to ask of an aluminum shaft?
Old 05-07-2006, 01:05 AM
blownerator
BlownChevy's Avatar
its not ALL about what it is made out of....although that is a % of why the drive shaft will let go. The important part is what it is made out of and what the critical speed is.
Old 05-07-2006, 01:08 AM
So is that a yes or a no?Sounds like it could work as long as its built for the speed i intend but what about the sheer weight of a x-cab truck?
Old 05-07-2006, 01:11 AM
blownerator
BlownChevy's Avatar
sure it can work if balanced.....I took my alum d/s out and went with steel. Stronger and higher critical speed.
Old 05-07-2006, 01:12 AM
La Riddler's Avatar
I called Denny's and they recomended a Hd Aluminum DS. Aluminum should feel softer than steel because of the weight diff. I'm getting mine soon....waiting to try it out and see how it feels.
sounds like if you have al then balance it but if you are replacing it the go with steel because its stronger even though heavier too
Old 05-07-2006, 01:14 AM
I think i might give Denny's a call.Woudn't a almuinum shaft be lighter as well netting a little more hp to the rear wheels....ethier way i don't want to race my buddies GT and end up havin the stock shaft fly out at 135 or more.....
Old 05-07-2006, 09:23 AM
agreif's Avatar
Just like what blown said, it's not the power of your vehicle or your weight. It's the speed at which any impalance pushes it over the edge & probably a little bit of what they call burst speed. The speed at which a rotating disk just breaks apart. Probably more of the imbalance but still. Looking at Denny's site it looks like they make AL's that will hold up, but have to call on Monday. Pisser if I have to get a full trans because my DS grenaded. What are ya gonna do, right?
Old 05-07-2006, 09:44 AM
Post
I'm no too sure if Denny's makes the two piece shafts in aluminum. I want to say that they are steel as well.
Jim
Quick Reply: 1st time on dyno, driveshaft grenaded, carnage insued (long)
