2001 Tahoe 5.3L Catalyic converter upgrade (help) :o(
hello, everyone.
i have a 2001 Tahoe 5.3L
i already have a borla cat back system....
do u guys know if borla make a cat for this truck?
or do u guys know what other company has good cats for this application?
have any of u already changed or gutted yours?
i was thinking about gutting it but i don't know if it will effect anything like the o2 sensors.
also i dont' want the truck to sound to obnoxious. but i do want it to roar a little....right now it only has a purrr.
thanks for all your help and comments in advance.
Destroyer of Transmissions
If you want to spend the $$ on a full cat back then Borla is a good choice. I had a Flowmaster (crap) it was loud and annoying with a lot of drone. I switched to a Magnaflow and like it much better. It sounds just a little meaner than stock on a normal take off but when you get on it, it sounds really good. I bought the muffler and had the shop weld it in and then weld a 3" pipe from the muffler to the tip. Everything before the muffler is stock. Cats are untouched.
yea i had flowmaster on my grand cherokee and was not to happy with it.
i already have the dual borla cat back system on my Tahoe, i just don't know what to do for a CAT . i don't think borla even makes one....i haven't been able to find any online, i just finished email there tech to see what they have to say too.
Originally Posted by sexyvic1
hello, everyone.
I believe its dynomax that sells an straight threw cat, I completely got rid of mine and the rear 02's its a great mod. Honestly Id redo the entire y pipe there is alot of power to be had in that area. GM does have an off road y pipe that is a direct replacement for the stock one. Ive never seen one though not sure if its flattened where it passes under the tranny.
when u got rid of the rear o2 sensor did u put anything in its place? does the check engine light come on at all now?
Try this go outside unplug the rear 02 sensors, drive it around it should set a light but it shouldnt effect performance. Make sure the wire isnt dangling on the exhaust.
14 Second Truck Club
nothing is there the whole y pipe was remade with mandrel bends. I deleted all associated rear 02 codes with hpt.
SLOPONY
20
10-18-2016 06:05 AM
ullose272
07-19-2015 04:14 PM
