2003 2500HD cam choices??
Old 09-16-2004 | 03:01 PM
marc_w's Avatar
Cool John... let us know what you go with and how it turns out.
(another Edit): I'm actually a little surprised he went with the 042. If you run a search for the 044, it's been mentioned in here a bit.
Old 09-16-2004 | 03:02 PM
Mr. Sandog's Avatar
Originally Posted by BIG JOHN
marc_w- I called VHP and talked with Roger...he thinks the 042 would work for me since I dont have a "hot rod" truck and tow a 6500 lb trailer and I want to keep my 33" tires-LOL-thanks-BJ
Considering that your stock cam is a (196/207 .479/.467 115), I think that anything less than the Comp 206/212 would be a waste of time, energy, and money. The Vinci 042 (200/208 .500/.500 115) isn't really even an upgrade. I think the 206/212 is ideal if you want to tow, but of course, you should get more input from Comp first.
Old 09-16-2004 | 03:08 PM
marc_w's Avatar
I admit that I do like the sounds of the 206/212.
I didn't have any luck talking with my particular guy from Comp. I told him that I wanted a torque cam I could drop in a stock motor. He kept pointing me to cams like the 212/218 (not that that's bad), and telling me to throw coverters and headers at the truck first. That's really not what I was looking for. I didn't want to "need" to have those parts - I simply wanted those parts to compliment the cam afterwards. He was telling me I need to build the motor first.
When I asked about the 206/212, he told me to put my stock cam back in because it wouldn't be worth it.
They basically turned me away.
Old 09-16-2004 | 06:35 PM
try thunder racing "oldman" camshaft
Old 09-16-2004 | 07:54 PM
Mr. Sandog's Avatar
Just because the Comp guys don't have a clue about the value of the 206/212 doesn't mean that the cam isn't any good and you shouldn't buy it. I think the 206/212 is a great cam, it would be perfect for me if the lifts were more like 550-560 (since I have a blower). Instead, I am looking at the Comp 208/214, 554/559, 115 (since it has higher lift than the 206/212), and also a cam from another manufacturer that is close to ideal at 205/211, 550/544, 114. For a N/A application, I would jump on the 206/212 in a heartbeat.
I do not want an aftermarket converter, and want to retain my full towing capacities. From all the people I've talked to (and I've talked to a LOT of people - not just people who make cams, but people who build motors for trucks), it sounds like anything OVER 206/212 is going to ensure a torque lag down low, perhaps until 1800-2000 RPM's. So given my reluctance to change my stock TC, I am leaning heavily toward the 205/211 with the decent lift, to give my blower some nice cavities to pump the air into...
Old 09-17-2004 | 09:19 AM
marc_w's Avatar
I hear you... I was ready to order the cam right then and there, but the guy was hell-bent on quarter mile times, which isn't my only goal. I called another shop (sponsor), and they talked me away from the 206/212 also. They were very helpfull, but I really wanted to hear about the 206/212. I just got frustrated and dropped it.
When I initially installed the 210/218, I felt it go a little soft under 1,500. I spend a few hours last night making some VE changes from 400-1600 last night, and have felt a "refining" of that area. I'm waiting for my fuel trims to settle out before I actually say I'm onto anything solid, but initial impression is that I cleaned up the power under 1,600 enough to pull seamlessly off idle with the stock 'verter.
I too am real picky about the stock coverter powerband thing, but I can honestly say that even before the above tweaks, the powerband was perfectly liveable. I understand the 5.3 will be a little more sensitive, so that 'over' 206/212 thought sounds pretty legit.
Old 09-17-2004 | 12:30 PM
Mr. Sandog's Avatar
Yeah, you've got more latitude with the LQ9, you've got 65 more FWHP to start with (the LM7 in 2003 only had 285 FWHP ). And a lot of your power is probably down low, so you will more than likely be very cool with the 210/218. But now you've got me thinking about that 208/214 again...
Old 09-17-2004 | 12:58 PM
marc_w's Avatar
Sorry!
Old 09-17-2004 | 02:15 PM
Mr. Sandog's Avatar
Mmm hmm, I bet you are....
Old 09-17-2004 | 04:57 PM
Is a cam swap as noticable of an improvement as a good tune??-BJ
Quick Reply: 2003 2500HD cam choices??
