2005 Predator programmers - with new features!
Diablo has just released their Predator programmer for the 2005 GM trucks that are powered by the 4.8, 5.3, 6.0 and 8.1motors -
NEW DiabloSport Predator U7193 Update Release on 1-17-05
The Following Predator revision has been released: R2.00
Part #: U7193 / 2004-05 4.8L 8.1L GM Trucks and H2 Hummer
Reason: U7193 Predator revision R2.00 was updated to add the following features:
• NEW Addition 2005 4.8L 8.1L GM Trucks and H2 Hummer
• Modified tunes for 03-04 and modified/added adjustable parameters.
New adjustable parameters implemented:
Timing Table 2000rpm-4000rpm (+15% / -20%)
Timing Table 4000rpm-7000rpm (+15% / -20%)
Fuel Table 2000rpm-4000rpm (+/- 20%)
Fuel Table 4000rpm-7000rpm (+/- 20%)
Idle (+/- 20%)
Speed Limiters
Rev Limiters
Part and Full Throttle Shift Points
Shift Timing
WOT Shift Pressure
Part throttle Shift Pressure
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
o Torque Management abuse mode time limit ON/OFF
o % torque reduction vs. RPM ON/OFF
o Up shift torque reduction (all gears) ON/OFF
Catalytic Overtemp protection Adjustment
o Disable P0430 and P0430 codes
o Adjust COT enable temperature
Multiple Misfire P0300 adjustment
o Misfire Low rev
o Misfire Low cyl
o Misfire idle cyl
EGR disable
o Enable/disable MPH, set high to disable
o Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
AIR code disable:
o Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code:
o Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160
and 0161
We will have this new version in stock very soon! We will also be extending our Predator programmer sale though January 31st. This offer is for the Predator, your choice of a 160 or 180 thermostat and free overnight shipping to locations in the 48 states. Orders can be placed online or by calling 1-877-482-9763.
Idle (+/- 20%)
Speed Limiters
Rev Limiters
Shift Timing
WOT Shift Pressure
o Misfire Low rev
o Misfire Low cyl
o Misfire idle cyl
EGR disable
AIR code disable:
and 0161
So finally the new programmers will have the ability to remove torque management huh? Will the new programmers work on my '04? I would sell my '04 programmer to a co-worker and just buy the new one if i'll have the ability to remove 100% of the torque management. is it true on the 04 tuners that If I restore my factory tuning to my truck, that it can be reused on another 04 truck? I thought you only had to send them in to get unlocked if your programmer was an 03 or older model.
Joe
Joe
The new programmer will cover the 2004 and '05 trucks. The Predator is usually married to your vin but I've heard some of them can be used on another vehicle if you return it back to stock. I'll check into this but I think it only applies to the Duramax.
Speaking of Duramax...
It doesn't take much $ to see BIG horsepower and torque gains from your Duramax truck!
2001-'04 (LB7) Predator contains five tunes to choose from:
Stock Tune: with adjustable speed limiters. Speed limiter to approximately 120 MPH varies based on vehicle set-up weight, tire size, 2wd vs. 4wd, etc.
40 RWHP and 100-ft/lb TQ - Tow Tune, made specifically for towing. DiabloSport recommended weight limitations based on manufacturer suggested limits for the vehicle.
65 RWHP and 150-ft/lb TQ - Economy Performance Tune, designed for Economy and Performance, fuel economy depends solely on driving style, and will vary from vehicle to vehicle. DiabloSport recommended weight limitations of 8,000 Lbs.
85 RWHP and 195-ft/lb TQ - Performance Tune, designed specifically for performance street driving. DiabloSport recommends this tune not be used for towing.
120 RWHP and 240-ft/lb TQ - XPerformance Tune, designed specifically for opening a can of whoop-*** (pardon the expression). DiabloSport recommends this tune not be used for towing.
2004.5-'05 (LLY) Predator contains five tunes to choose from:
65 RWHP and 140-ft/lb TQ - Economy Performance Tune, designed for Economy and Performance, fuel economy depends solely on driving style, and will vary from vehicle to vehicle. DiabloSport recommended weight limitations of 8,000 Lbs.
85 RWHP and 170-ft/lb TQ - Performance Tune, designed specifically for performance street driving. DiabloSport recommends this tune not be used for towing.
100 RWHP and 250-ft/lb TQ - XPerformance Tune, designed specifically for opening a can of whoop-*** (pardon the expression). DiabloSport recommends this tune not be used for towing.
We currently have these programmers on sale for $359.99 with free overnight shipping!
As far as I know this will only cover the 2004 and '05 trucks (one part number for them). I'll see if they plan on offering the same options for the earlier models.
