2006 Silverado will not crank. How odd.
Nothing leading up to this. Battery is good, good connections, starter is not dragging.
Went to grocery store, stopped again at a gas station on the way home to get some Sprite. Got back in. All dash lights, a/c radio, windows, horn, ect. All work. Nothing at the ignition/key switch.
I know the usual suspects, what I dont know, is the the security/anti-theft issues that could prevent it from cranking. It was dark when i got it home, so I didnt get a chance to check any fuses, or check any connections to the starter. I do think I hear the selenoid click when I hit the ignition.
Where should I start?
There's a possibility the power cable under the oil pan has corroded out but it is usually more intermittent than not at all.
13 Second Truck Club
I had that same exact problem I would have changed the ignition switch but I was out town working and didn't have time to wait on ordered parts. I dropped the truck off at the dealership they replaced the battery and the ground lead. The battery was not that old and the main ground wire looked near perfect. I think the problem was the ground wire the whole time.
ARC
57
02-21-2022 10:54 AM
FlowmasterMufflers
07-17-2015 03:26 PM
