2006 Vortec max
Old 04-01-2010, 03:44 PM
mudingbuck's Avatar
Default 2006 Vortec max
I have a 2006 Silverado Vortec Max. Does anyone know what i have from factory. Like, heads-L92?, rear end 4l70?, I know it has 4:10 gears. Lt has a LQ9 6.0 L, is that ALUMINUM block?
VORTEC MAX PACKAGE: includes (LQ9) Engine, Vortec high-output 6000 V8 with "VortecMax" engine cover, (M70) Transmission, 4-speed automatic, super duty, (GT5) Rear axle, 4.10 ratio (includes (GT4) Rear axle,(G80) Differential, locking, heavy-duty, rear, (ZX3) Suspension Package, Ride-Control, (KC4) Cooling, external engine oil cooler, (KNP) Cooling, external transmission oil cooler, auxiliary, and (Z82) Trailering equipment, heavy-duty (NHT)
Old 04-01-2010, 04:31 PM
I have a gauge for that
Atomic's Avatar
Heads: 317
Trans: 4l65e
Rear: 14b SF 9.5"
Block: LQ9 (iron)
The aluminum block 6.0 is the LS2 (in the TBSS). The LQ4 and LQ9 truck engines are iron blocks.
Old 04-01-2010, 04:42 PM
Bo185's Avatar
M70 rpo should be 4l70
Old 04-01-2010, 04:52 PM
Atomic's Avatar
isnt the only difference an input speed sensor?
Old 04-01-2010, 07:50 PM
Bo185's Avatar
Correct.
Info - New Product Announcement - 4L70-E (M70) Automatic Transmission #05-07-30-026 - (Oct 7, 2005)
2006 Chevrolet Silverado, TrailBlazer SS
2006 GMC Sierra
with 4L70-E Automatic Transmission (RPO M70)
General Motors Powertrain required a version of a current production rear wheel drive transmission capable of handling higher torque and horsepower without going to a larger size transmission. As a result, the 4L70-E was created. Very much like the 4L65-E, the 4L70-E shares many of the same components and adding premium materials and additional manufacturing processes, the 4L70-E is capable of handling up to 400 horsepower and 430 foot-pounds of torque. It is also capable of increasing shift speeds up to 6000 rpm.
The 4L70-E will be first introduced in some 2006 mid-size sport utilities and full-size pickups. The 4L70-E will be identified as RPO M70. The M70 will use the large 300 mm (101K or 112K) torque converter. Some M70 models will be the first 4L60 series transmissions to receive the new input speed sensor (ISS) .
Below are the 2006 4L70-E applications and models:
• Sport Utility 4L70-E models with ISS: SKD/TKD
• Full-Size Pickup 4L70-E models: CMD, CWD & KMD
Important: The following graphic and table describe only the essential components that make up the M70 transmission model and will not identify all parts.
The following identifies the 4L70-E (M70) components and the components it shares with the 4L65-E (M32) transmission.
Item Number
Part Description
ID Feature
RPO M32
RPO M70
300 mm/112K Torque converter (1)
• Identification code label affixed to the convert cover
• Outer diameter & lug size
X
X
5-Pinion input carrier Asm. (662)
Number of pinion gears
X
X
7-Plate 3-4 Clutch Asm.
(7 friction, 6 steel plates)
• Number of friction plates
• Steel & apply plates have "HD" stamp
• Friction plates have Identification stripe
X
X
5-Pinion Reaction Carrier Asm. (681)
X
X
Reaction Internal Gear Asm. (684)
3 machined grooves
X
Output Shaft (687)
One identification band
X
HD Low and Reverse Roller Clutch Asm.
Bronze clad cage
X
X
Input Sun Gear and Forward Sprag Asm (642)
Paint marking
X
X
Input Turbine Shaft
X
X
Stator Shaft
Darken splines
X
X
Refer to the appropriate SI section for additional repair, diagnosis or description information.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Old 04-01-2010, 08:12 PM
11 sec. Truck Mod
TIM Z's Avatar
Good info, thanks for posting.
gaps
10-15-2015 02:53 PM
BlownHD
10-03-2015 12:24 PM
02AWDAWSDenali
10-01-2015 05:08 PM
Cammed4ever
09-30-2015 03:38 PM
bisqikss
09-27-2015 09:40 PM
Quick Reply: 2006 Vortec max
