2010 chev 6.2 WOULD NOT MAKE POWER ON THE DYNO?!? WTF!?
my 9.8:1 AFR is what the stock tune produced before any changes were tried... that is what his wideband showed. so either the 02 sensor is out to lunch or GM made it that rich for a reason... it showed 14.7 or so when it needed to be like part throttle and idle. you would think its close then.
thats why im asking if others with same engine having trouble getting more power out of the stock configuration. wouldnt think im the only one.
i will try a more open intake and exh and should see some improvements if one or both are choking the eng back.
11 Second Truck Club
It made 250 rwhp through a transfer case and automatic trans, probably on big tires. Its perfectly on par for what it is. Anything short of forced induction and your wasting your money.
i am running 91 octane. i will have to take my predator handheld and laptop and do a WOT log to see where everything is at for timing. havent had a chance to yet.
like i said before... even when he tried leaning out the AFR from stock readings the engine dropped power. so yeah its real weird.
the one thing i noticed after though was the fuel mileage was better. driving at 120 km/h it was holding at 14.1-14.3l/100 km. i found out that the 6.2 engine does not cut down to 4 cylinder mode like the 5.3. i thought all these newer engines have AFM.
its not 100% accurate but everytime i fill up the actual litres and fuel used is always with in 1 to 2 litres. fairly close.
that 6 speed is nice for cruising. at 120 km/h eng is running around 1950 rpm. i have the 3.42 gears. im getting same mileage as my 08 5.3 running 110km/h but it had 3.73.
i feel like mine is running a whole lot better now that i got some miles on her....
also ive noticed mine is sluggish after i fill it up with gas.. only thing i can think of is that the flex fuel is making the truck rich untill it figures out what fuel is in the truck...
maybe thats what is happening here???
but all in all i still dont think its too far off... only thing that bothers me is that when he played with it nothing changed.. didnt make anymore power...
as far as the fuel thing... it had ran thru almost half tank of gas till i drove to dyno shop. plus 91 is all ive put in it. but you never know i guess.
