2013 Escalade ESV in the 13s with bolt ons only
I got my escalade ESV (suburban sized) to run a 13.9 at 99.6 the other night. Full bolt ons running on a killer e85 tune. I run Silverado aluminum 17s at the track with slightly shorter tires. Took every seat out but the driver seat plus running boards. Lost over 300 lbs not including wheels. My 60' is still a 2.1-2.2. How much can I gain from a 3000-3200 stall?
Ps if you're in the Pittsburgh area hit up jake at domin8tuned. He's the best.
13.3 is the listed stock 1/4 mile for an SRT jeep...at least that ive seen. That would be crazy to run that fast. How does a converter affect WOT acceleration? Like would it only benefit out of a holeshot or would I see a change roll racing as well?
<p>There is a small benefit to roll racing as well because you no longer will be as concerned about perfectly catching a gear right or feeling like it has fallen on its face after a shift. The converter stretches to a fatter part of the torque curve and gains effiency at higher RPM.</p><p> </p><p>The most simple explanation is this. At your peak TQ the truck wont really pull any harder than it does now in any gear. The converter will allow for more consistent acceleration with no 'soft spots', most notably fixing the soft spot we experience off the line.</p><p> </p><p>And on the SRT front, that is very impressive, you're right! From a roll you will have a hard time with one though as they trap a few MPH higher, and you likely wont gain enough to keep pace with them from the converter alone. I could see you breaking 100 and very possibly hitting 101, but I think those are closer to the 105 ball park.</p>
yeah id probably still get pulled on but id be able to hang close enough to irritate the owner haha. ive contemplated the ls9 cam swap as well. I bet a converter and cam would have me even maybe slightly better
ive been emailing circle d about a converter. they recommend a 3000-3200 stall for me since its a daily and its only like 500 bucks. problem is ill also have to do a tranny cooler because the 6l80s run hot to begin with. and those things are heavy as ****. I will have to make a friend with a lift haha. what do people have luck with for tranny coolers? I can put one of those in before I do anything else
keep vvt or not?
