206/212 cam guys
#24
If you're positive you're going to get a different converter, that opens you up to bigger cam possibilities. If I had a higher stall (like the TB one you are looking at) I would seriously be looking at something like a 210/216 or 212/218. If you're willing to go 212/218 (which you should be able to do with a 2000+ RPM stall), you would likely be able to find someone selling one of those, as they are very popular here. There is a low-lift and a high-lift version of that cam, either one would work. I bet you could pick one of those up for $200 (give or take) in the classifieds. Just post a 'WTB: 212/218' and I bet you get a taker.
#25
i just think the 212 would be to big for my truck.. stock idle is a must since im **** about idle.. i have the thumpy stuff in my car so i dont want the truck idling like my car. Car idles great, but i couldnt stand he sound 24/7:-P
208/114 is probably as big as i would go if thats possible
#26
I don't think duration is the only factor in idle quality, I think LSA and other things go into it as well. You can do a lot with a good tune. I bet you could tune a 212/218 so no one knows you have a cam, even you. But if you're not going to get a tune, that is definitely a consideration. I will tell you, my little cam (with medium lift) does not idle like stock. I mean it's close, but it lopes a little bit. May have more to do with the lift (.548/.540), LSA (113.6), and lobe design than duration, though....plus all I have for a tune is the stock SuperChips Radix tune.
#27
PT's Slowest Truck
#28
oh come on.. both you guys dont like your 205 and 206 cams.. take them out and give it to me:-P
AV, i dont mind a lil lope.. just didnt want so much it annoys me and stalls out.
Ill probably get the vinci tuner, if not then a nelson tune later on. But i wanted something I could place in there and still idle great at stock rpms for about 2-4months
#29
PT's Slowest Truck
My truck runs great with the Crane/Vinci tuner set to cam1, bump idle up 50rpms, and increase shift timing and firmness. Awesome around town. Now at WOT, my PCMforLess tune is unbelievable.
I like my cam, but you know how it is...you start thinking what if I did this, or what if I just had a little more lift and a tighter lsa...it's like the newness wears off, and you want more!
