20w-50 oil to much?
Old 07-27-2006, 01:14 AM
Dark Halo's Avatar
Default 20w-50 oil to much?
I swaped the pick up tube oring and my pressure is a little better but I was told to try using 20w-50 oil in order to help boost the pressure. What are your thoughts on this. I have been using 10w-30 and I plan on swaping to royal purple or castrol syntec on my next change.
Old 07-27-2006, 01:18 AM
20w-50 is some THICK oil. woudl help boost pressure but adds a bit of resistance on all of your valvetrain components. i wouldnt go as extreme as that for now. can you get something a little more in between those. like 20w30 or 10w50 or something?
Old 07-27-2006, 09:25 AM
Dark Halo's Avatar
I thought the same thing, I know 20w50 is used in Diesels but It told to me by a friend that is why I asked. My pressure is only low when it is hot. When it is cold it is good.
Old 07-27-2006, 10:03 AM
how low is low? are you talking like 30psi? call a local mechanic and ask him what he thinks if you arent getting many responses here
Old 07-27-2006, 10:30 AM
Coban's Avatar
Your engine will have an ever-so-slightly harder time moving with the thicker oil. I use 15w40 and have never had a problem. It was made for diesel engines and I get it for free where I work. This oil had extra detergents and my engine was CLEAN when I opened her up. Thicker oil is also better for high rpms I think.
Old 07-27-2006, 10:45 AM
Dark Halo's Avatar
well by GM specs its good but at cold Idle I am now at 40-45 and hot idle is about 30. Cruise is about 45 or so hot. Before I swaped in the 6.0 my 4.8 cruised at 50-60 or so with the ported oil pump. I only noticed this drop when my oil sending unit went out and I replaced it with an oriley sending unit vs a delco unit. The only reason the thicker oil was suggested was because the oil is thicker when it is colder, so a frind of mine suggested an oil that is a little thicker when hot. I really just want was is best for my new motor. I replaced the oil pick up tube oring last night and my oil pressure bummped a little higher and the liffter tap is now gone. I had the wrong oring on when I put the motor together, my new one I got from the dealer was almost twicw as thick as the one that came in my lower end gasket set which I also got from orileys. It was a black oring to where the one the dealer gave me was thick and red in color.
Old 07-27-2006, 10:50 AM
Hunt&Fisherator
silver-mod-o's Avatar
I run 10-40 in mine with no problems. if its a harsh winter I'll go back to 30W for a couple months
Old 07-27-2006, 10:53 AM
Dark Halo's Avatar
well I am sure as you know here in the beaumont area we are not known for harsh winters. I think I wore shorts mosly this last winter.
Old 07-27-2006, 11:00 AM
Hunt&Fisherator
yeah... I totally forgot you were down there LOL... it does get pretty damn cold up here in VA though. (at least its cold to me)... I say you'd be fine running some 40W... 50 may be a little much. you think the sending unit may just be off some?
Old 07-27-2006, 11:45 AM
w41quad4's Avatar
One thing many people misunderstand about using a heavier oil is that while oil pressure might go up that in no way means that your oil volume is increased. I've seen a few engines turn to **** because someone ran a heavier oil that made good pressure but actually starved the engine in certain areas for oil, due to its in ability to flow as much heavy oil as thing oil.
Quick Reply: 20w-50 oil to much?
