224/228 112lsa cam
224/228 112lsa cam
i just watched one of circusboy's videos (badass truck btw), and i love the way his cam sounds.
From what i can tell, its a FMS Cam FM-5 112 +4
What i want to know is, would a stock TQ converter work with this cam temporarily while I save up for a Yank TT3000, Vigilante 3000/3200 or even a TBSS converter?
Also, who makes a good cam with those specs? and prices?
I'm gonna go poke around on Summit and Jegs for awhile and see what I can find.
Any cam is going to be around $400.
ouch, maybe that cam is a little more than im wanting then.
Would a 220/220 112lsa still have that lope to it?
From what ive read, just about anything on a 112lsa is gonna lope pretty good.
I was gonna go with a ls6 cam and springs, but i want it to actually sound like i have a cam
Well, peak lift shouldn't matter. The duration is how many degrees of rotation the valve is open from .050 of lift until closed, peak lift shouldn't be a factor in play here. LSA is just the spread between ICLs, it should be a universal measurement irregardless of peak lift or type of cam. Lift is a measurement from the cam outwards. Duration and LCA are measurements regarding around the cam in a circle. I'm by no means a cam expert, but I have played with and researched a lot of cams for Gen II engines, I just don't understand how they can have such an adverse affect on driveability over a regular carbed engine. Unless it has something to do with the way the computer views the engine processes.
To me, a cam with 220* duration on a 112 LSA is a small cam, like an RV cam, but it seems as though these engines view that a little differently than the predecessor engines. I never even began to think a cam started getting "big" until you got into the 235* area.
Sure, you can put any cam in and still use the stock converter. Just be ready for a lazy bottom end. 5.3s are smaller in displacement than the GenII (Assuming LT1 and LT4) that you are used to, and therefore produce less lowend torque right from the start. A stock 5.3 has a torque peak around 4500 rpm. Start throwing 224/228 duration cams in and you're going to lose a lot of lowend and raise your torque peak even higher, which is why people are recommending 3600 rpm stall speeds with this cam, espcially in an extended cab.
A 220 duration cam is a good mid duration cam for a 5.3. Definately not "RV" cam material. If you just love the sound, maybe look for something "3/4 race".
