234 228 cam
Originally Posted by benpimpin1
I would put the fucken ls6 crank in because as of now the engine on my engine stand is a 4.8 which is the same block as the 5.3, which has the same stroke as the ls1. So you see why i would put in an ls6 crank. It is a higher quality and lighter than a stock 5.3 crank also.
Secondly what should kind of cam should I go for if I am to supercharge it?
how does the truck run with that 226 cam? I have seen a package for the 5.3 that is around 234 227 with stage 2 heads I will have to check back to see who makes it.
