243 Heads
#31
Don't bother with the 243s on a 5.3. The 5.3 has a small combustion chamber so it's better to go with a 5.3 casting with 2.0 or 2.02 valves and have them milled. If you go with 243s you lower compression, yes you can mill them but you will only get back to stock CR. TSP has some nice stage one 5.3 heads, with good springs for like a little over 1000.00 and they will mill them for free. I have seen several people use 64cc heads on 5.3 engines with no gains. If you have a NBS you can use the stage I 243 casting with a .030 mill and you should see some good gains.
#32
14 Second Truck Club
#33
I had my heads P/P for 500.00 and bought manley 2.0 valves for like 90 buck just the intake valves. The person who does your heads can mill the heads and install the valves and springs. The 243 casting is a good casting, but not for the 5.3. If you are going to go with a 6.0 just save that money and invest it on the 243, but worked heads with good springs and valves. If you buy the stock 243s you still have to invest some money to increase flow and upgrade valves and springs. It's easier to buy them already worked and ready to install.
#34
patriot will weld the chambers shut and report them to any CC that you want. so you can get a 243 head with 59cc without milling them any at all.
#35
#37
Restricted User
03regcab sierra
09-09-2015 02:02 PM
BigEd_72455
08-08-2015 04:49 PM
