243's on an lq4 how much can i mill them
Old 09-10-2007 | 12:04 PM
11 Second Club
Default 243's on an lq4 how much can i mill them
i am running an ms4 cam in my ls1 but spun a rod bearing so i got an lq4 how much can i mill these heads using a stock gasket before i run into p/v problems? .649/.610 lift
Old 09-10-2007 | 12:20 PM
Quik's Avatar
5 year bitches!
did this similar mock up a little ago. 00 LQ4 +243s +Ms4+ .074 clearance. that was with stock gaskets
compression will be around 10.5
Old 09-10-2007 | 01:07 PM
11 Second Club
so then how much could i mill the heads and be still safe?
Old 09-10-2007 | 01:20 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You shouldnt mill them at all, thats getting close enough.
Old 09-10-2007 | 01:55 PM
silver-mod-o's Avatar
Hunt&Fisherator
the most I'd go is a .005 or .010 clean up mill job.... I wouldnt mill them for the sole purpose of gaining compression. like Cody said, they are already getting sketchy...
Old 09-10-2007 | 04:23 PM
Quik's Avatar
5 year bitches!
you should have .080 clearence the ms4 has .074 with that setup.......no milling allowed
gmcyukon
10-03-2015 11:03 PM
02AWDAWSDenali
10-01-2015 05:08 PM
tim wellington
09-29-2015 10:17 PM
old motorhead
09-29-2015 08:22 PM
Slammed silverado
09-28-2015 06:14 PM
Quick Reply: 243's on an lq4 how much can i mill them
