2wd vs. 4wd 4l80e
It just needs a new Output Shaft and Housing. That's the easy part. A complete disassembly is required to get to the tailshaft.
Housing: 8677464
Output Shaft: 24204289
I'm fairly sure the housing comes as an assembly with the outer and inner seal and the bushing pre-installed. Six bolts will be required to hold it on. Two bolts hold the rear mount. The rear mount is the same as a 2WD 4L60-E but not a 4x4.
EDIT - looks like I read it backwards. The above info is for making 2WD out of a 4x4.
Housing: 8677464
Superman09
09-25-2015 05:55 AM
Alvin@PCMofNC
09-03-2015 06:38 AM
